Camo mesh SS - many pics :)
Oh puke :p:
Nice and clean build as always. :up: What exactly does the coils on the hot side do? Sorry if my terminology is off. :shrug:
Another Monster Single Stage unit from Ron, nice work :up::clap:
Originally Posted by
chuchnit
Oh puke :p:
It cools hot gas coming out of the compressor and acts as a damper of sort.
runmc
Gotcha. Figured the extra coils had something to do with extra length for cooling. Your brazing skills are sweet. :yepp:
Very nice work as always !
Sweet looking build Ron:up: Excellent craftsmanship !
Been away a few years and didn't know you were into the custom
phase change business. I would assume these units can hold a load better, colder than the revamped 404 and 507 Prommies that we used years ago.
Great to see you're still up to your ears in the hobby:)
Best regards,
Randi:D
sdumper
I just hope it cools as yours.
MrIcee
Best regards,
Randi:D
It keeps me off the streets Randi - It's very good to see you. I hope all is well. :up:
Look at you with the Scotch-Brite and copper :up:
I'm sure he will enjoy it :clap:
Ron that accumulator looks amazing. Do you use some sort of gloss or touch up coating and if you do can you send me a PM with some tips for applying it.
chuchnit
Oh puke :p:
the discharge gas from the compressor is so extremely hot that just running it through coils like that in front of the fan lowers the temperature quite a bit... so the condenser has to do less work :up:
teyber
Thanks teyber :up: I figured it was for some cooling effect, but wasn't sure if the extra length is tubing was for something else all together. :shrug: I know about this much for phase change, but they do intrigue me.
1 Attachment(s)
sdumper
No need for PM :D
I bought it at Home Depot. Just spray it on.
Awesome!!!!!
I always wondered how everyone made there copper so shinny after cooking it and melting brazing rods of silver on it :)
As always nice work Ron. :up:
Praz
Thanks John but yours is still the best of all. :up:
sdumper
Awesome!!!!!
Have you made it back from Home Depot yet? :ROTF: If they don't have the paint there, check at ACE Hardware. ;)
Any new pics? Frosty ones? :D
1 Attachment(s)
chuchnit
If you look closely you can see frost on the suction line close to the compressor:D
Unit is now tweaked for -35C at 305watts. I don't want to flood the compressor but at the same time, I want to keep the compressor temps down.
Ambient temperature makes a lot of difference with these units. A warmer benching room will definitely make for a warmer evap temp.
Keep you benching room cool for best results. :D
runmc
Thermostat gets set on 66-68f when I'm benching. ;) That camo mesh is really growing on me too. :D
what compressor did you use?
sc18cl maybe?
Duniek
sc18cl maybe?
yes sir :up:
Good looks and performance! Those condensing units are a great basis to start from.
One question though, why not run the camo mesh all the way back to the compressor and make it even prettier?
