lost the CPU Turbo option in Bloodrage... how to restore?
Hello.
i have the strange problem. about 2 months ago i have the i7 950 cpu / bloodrage GTI with p08 bios and all was fine.
the option CPU Turbo : (always on/auto/disable) was in place.
i decided to flash to new G32 bios - flashed succesfully. all was fine.
then i replaced the i7 950 with a Xeon W3520 and.... this option dissapear from bios settings - no more CPU Turbo option for me...
i flashed back to p08-p09 - no effect - no option.
then i changed W3520 to the new one (good OC) 950. and... still no CPU Turbo option :(
i have no idea how to restore it ... :shrug: i flashed both BIOS'es to older version, did full reset, load optimized defaults and so on, but nothing helps and there is still no option in the bios :(
when i turning the PPM on in the CPU Features - the mobo automatically makes turbo multiplier permanenltry. Now if i turning on the PPM (EVEN if EIST off - earlier the turbo worked for me only if both was enabled) i get permanent x24 multiplier.
i'm need very much to get this option back, because i want to turn CPU Turbo in disabled state by this option and use PPM and EIST (this giving me rock stable voltage on the core - the exact as i set it, with PPM and EIST off - and x23 multi that i need when i set the 1.45 vcore - it gives me 1.42 in idle and 1.45 only under full load - linpack e.t.c - so i have many issues in the applications such as games - the voltage are fluctuating between 1.42 and 1.45 due to load on the cpu and sometimes i hanging).
any ideas? may be i need to reflash both bios'es on programmator? i have one on the work, but should it help? where and how this option "stored" and how it can dissapear and not appear again??? :confused:
