I know Aquamark 3 is going on 10 years but I'd like to run it for kicks ;)
Does anyone know how to get it to run in windows 7 64 ??
I've tried all the different compatiblity modes and admin but no go.
on the 4870 in your sig? What happens, wont even run?
Try deleting the .dll in the aq3 program folder. Seems to cause alot of trouble with ati.
Btw your score will be rubbish in win7 ;)
Try this
Link
Thanks!!
212,524 lol
It took like 50 seconds to run all the way through
Be a little renaming guy and you'll score better ;)
Scores rubbishly :( so crapp bwark!!! XP x86 is the way... ;) Even multi GPU stucks around 220/230K when on XP I hit 300K+
But for Aquamark and 01 on CrossX configuration I gat issues to clock the second card with Afterburner 1.5 (only on XP)
It appears that only 03 reacts well on Seven64, using the 3 OSs atmo ...very painfull :/
Vista32 gives me lot of satisfaction for 05/06 and Vantage :yepp: (Gautam was right so, right!!)
in w7 u can alt/tab for task manager and set affinity and set all cores
Use the patch Brian is suggesting...
Rename the Aquamark.exe (program files x86) to anything you like...
Delete the directcpll.dll...
Use real time priority...
Tighten your memory...
Use a bit of lod and you're good to go!!!
Try it in W7 32bit, 64bit doesn't seem to help anything. ;)
I found this thread searching for help getting AM3 to run on Win7.
Thanks!
To bad there is not 10 yrs worth of scores living on the www.
General:
Name: Benchmark 2010-07-11 03-52-02
Processor:
Vendor: GenuineIntel
Name: Pentium(R) III Xeon processor
SpeedMHz: 4200
Type: 0
Family: 6
Model: 10
Stepping: 5
Flags: 0xBFEBFBFF
Number: 8
HyperThreading: n/a
MemoryOS: 4294967295
Graphics:
Description: NVIDIA GeForce GTX 295
Vendor: 4318
Device: 1504
SubSys: 105779422
Revision: 161
CoreClock: 0
MemoryClock: 0
Driver: nvd3dum.dll
DriverVersion: 8.17.12.5869
VideoMemory: 3869245440
TextureMemory: 3855613952
OperatingSystem:
Version:
Type: Professional
Build: 7600
Run0:
DisplayWidth: 1024
DisplayHeight: 768
DisplayDepth: 32
AntialiasingMode: 0
AntialiasingQuality: 0
AnisotropicFiltering: 4
DetailLevel: 4
AvgFPS: 253.876160
MinFPS: 164.000000
MaxFPS: 392.000000
AvgFPSRender: 449.027039
AvgFPSSimulation: 583.853516
AvgTrianglesPerSecond: 76424888
MinTrianglesPerSecond: 12060352
MaxTrianglesPerSecond: 239154765
AquamarkScoreRender: 44901
AquamarkScoreSimulation: 29193
AquamarkScore: 253876
errrr, have you ever heard of hwbot?
We need newer benchmarks!
*cough* heaven *cough* :)
hey rich wil it be a benchmark that will score points ???
