running on a 360 atm will be 480 soon, 3 blocks total ek nb/sb and xt, I have no idea so just checking everything seems ok have done prime/linx for about 10 minutes each.
What are you using to monitor the temp?
Real temp with motherboard sensors for the cores
60C seems to be right what are you running for vcore?
1.30625, I just copied this template exactly.. http://www.clunk.org.uk/forums/revie...html#post80455
Its ok. Im running ~ the same with my GTZ and MX-2 thermal paste. Its also ROOM temp related.
That's a pretty decent temp actually.
yeah that temp is pretty good, when i run WCG at stock maxed on a gtx 480 i get those temps :shrug:
thats fine, you dont even have to get a 480 rad- it wont lower your loads any more than what the 360 is doing now.
not much at all. lol I speak from experience, err ignorance, I have a quad XSPC RX, a triple Feser, and a triple XSPC RX on the CPU loop, and 2 swiftech triples for the GPU loop in the works.. :rofl:
phase = loud, 750 RPM GT = quiet. ;)
Well I'll be changing anyway the 360 is for my gpu loop and 480 for cpu/nb/sb (my first 480 I punctured with screws too long, leaked to hell and back :(). I do have another question though, when I run speed fan one of the motherboard sensors shows a constant 63-64 (load or not makes no difference) how can I find out where this sensor is and fix this? I have an ek fc block for my giga ud7, the other 2 sensors report 38 or so.
On my motherboard the temperature sensor is located way off near the edge of the board right under where the video card's fan exhaust exits the case. I know this because I can hit that spot with a stream of compressed air and cool it right down. That motherboard sensor means practically nothing and is totally useless.
Awesome thanks.
reseated xt temps are lower but difference between cores is quite big maybe didn't spread tim evenly enough or is it no biggie?
http://i787.photobucket.com/albums/y...LOWPOKE/hi.jpg
