Gskill for P55-FTW
Hi
I want to buy a gskill memory for my new P55-FTW (non 200).
My problem is that I want a high speed ram, and looks like best rams arent compatible with my board and yes with ftw 200.
Can be possible that this info its outdated or inacurate and I can use some of the next kits with my board?
http://www.gskill.com/products.php?index=258
http://www.gskill.com/products.php?index=257
http://www.gskill.com/products.php?index=251
http://www.gskill.com/products.php?index=215
thanks
I have the 2133 tridents they work fine better than fine actually. have gotten them to 2200mhz no sweat
tridents will be great more options with good bbse than the 2200 cas7 i got
i shoulda saved $ n got the tridents lol
Also runnin g tridents on a p55 ftw non nf200. works a1 !:up:
Those are all the top models, so it simply depends on what you're looking for. For the DDR3-2200+, hopefully you have a good i7 CPU. =)
Thank you
GSKILL TECH
after burnin the 2200 pi in my rex @ 1900 cas6 they are working alot better in evga ftw p55 finally got em to work on 5:1 divider:)
before i was stuk on 12:1 so wasnt a bios issue;)
