Are there any waterblocks that have the same dimension as the HR-09 S TYPE 2,or is known to fit this mobo.
http://img29.imageshack.us/img29/7447/87727924.jpghttp://img190.imageshack.us/img190/4364/43173330.jpg
- 84(L) x 15(W) x 14.1(H) mm Enzotech WMST-78NP
Does the measurement cover pin to pin or the base plate on the water blocks.:shrug:
- 72(L) x 16(W) x 19.6(H) mm Enzotech WMST-66NP
Check Enzo's site.
http://www.enzotechnology.com/water_cooling.htm
Pin hole doesn't look like a match :mad:
- 84 X 15 is what I measured on the board,thanks for reply.:up:
Nope, the Enzotech probably wont fit :(.
Make sure your heat plate is long enough to cover all the mosfets.
http://www.koolance.com/water-coolin...product_id=658
http://www.koolance.com/water-coolin...r-plt76_p0.jpg
Then get the mosfet block which is associated with that heat plate.
http://www.koolance.com/water-coolin...product_id=660
http://www.koolance.com/water-coolin.../mvr-40_p0.jpg
And then put them together like this:
http://www.koolance.com/water-coolin.../mvr-40_p2.jpg
That is about your best choice minus getting it customed.
Site is down :(
Just to give you an idea of what Naekuh was talking about:
Your heatplate:
http://www.performance-pcs.com/catal...ducts_id=26629
The associated mosfetblock:
http://www.performance-pcs.com/catal...ducts_id=23417
You install the heatplate on your mosfet and the mosfetblock goes on top of the heatplate. The heat get transferred through the plate to the mosfet block.
I believe the heatplate is installed using a thermal pad of some sort.
Do these come in all copper ? I guess not.
It's all nickelplated copper, but I don't think they come in an all copper version.
