XFX 260GTX Black Edition - pink screen crash
Sometime around last April i bought a XFX 260GTX Black Edition and untill two weeks ago i have been completely satisfied with it. Recently it as started to crash. :mad:
At first i didn't thought it could be the graphics card but after some tests i found that if the card goes anywhere above 77/78Cº it just crashes. I get a pink screen and that's it. Reboot.
When i bought it i run Furmark and all those benchmarks and the temp sometimes went past the 80's. Not for long though cause i don't like to stress my hardware unnecessarily and things were fine. Despite this behaviour it works flawlessly. On most games temps don't go above 65Cº, but on those who require a bit more juice it easily used to sit at around 78/79Cº. And it used to be of no problem.
Until recently, when it started to crash. I do know that normally stock coolers are kind of lousy at doing their job. But as this one kept the card idle at 32Cº and when playing on an average between 65/75Cº i thought that is was doing an acceptable job.
Cranking the fan up won't solve the problem either. It will only take more time for it to crash. Eventually, with the right conditions (game or benchmark), the card will it the mentioned temperature and crash. Not to mention the noise. :down:
The only solution i've found is to downclock its values to the reference ones for the 260GTX cards. With those, theres no kind of problems whatsoever.
I've researched already and i've found others with the same problem. And it's not that rare with these 260 Black Edition cards.
What's the position by XFX on this? Does XFX accept a RMA based on such problem and at this lifetime of the card?
Kind of disappointed...
