My Short Quick Run of MSI R5970-P2D2G
Wooohooo!!!! One of my upgrades upon starting 2010 :) hehehehe
http://i31.photobucket.com/albums/c3...70/5970Box.jpg
http://i31.photobucket.com/albums/c3...ccessories.jpg
Some Few Specs of the card
Core: 725mhz Core
Memory: 2GB DDR5 4000mhz
Video Output Function:Mini DisplayPort x 1 / Dual-link DVI x 2 / VGA (via DVI to D-Sub adaptor) x 2 / HDMI (via DVI to HDMI adaptor) x 2
Features
■Over voltage function of GPU
MSI's own "Afterburner" overclocking software that allows the user to adjust both the voltage and overclocking settings for better performance.
■40nm Dual GPUs + 2GB GDDR5 Memory
Dual 40nm 5970 GPUs + 2GB GDDR5 memory provides the greatest performance on the planet.
■DirectX 11 & OpenCL support
-Support the latest DirectX 11/Shader 5.0 and OpenGL 3.2 graphical standards.
-Support OpenCL (Open Computer Language) to execute parallel computing by GPU.
■ATi Eyefinity Technology
- Support up to 3 monitor outputs simultaneously and independently.(one of the outputs must be DisplayPort.)
- Maximum 3 * 2560*1600 resolution.
- Improve work productivity and provide better gaming experience
http://www.geeks3d.com/public/jegx/2...ponants-02.jpg
Now for my Test System
■ Processor: i7 920 C0
■ Cooler: Titan Fenrir
■ Motherboard: MSI X58 PRO
■ Mems: 3x2GB Kingston DDR3 1333mhz
■ PSU: AcBel M8 670 Watts Modular
■ Harddisk: WD Raptor
■ OS: Windows 7 Ultimate 32bit
http://i31.photobucket.com/albums/c3.../5970Setup.jpg
See how long thy card!!!
http://i31.photobucket.com/albums/c3...0SetupSide.jpg
Some few benchmarks
all settings @ stock
http://i31.photobucket.com/albums/c3...ck3dmark06.jpg
If you noticed at all stock settings, we have a bottleneck already and it was the processor. So if you guys are
are already planning to buy this kind of video card. You "should overclock" you system up to 3.8ghz or better 4.0ghz
Next i7 920 running at 4.2ghz. No OS or software tweaks. Just wanted to see if I will be getting a higher score with
an overclocked processor
http://i31.photobucket.com/albums/c3...ark06stock.jpg
The score went up from a bottleneck processor awhile ago
http://i31.photobucket.com/albums/c3...ntagestock.jpg
So i will try to post some more benchies if I have the time. Will be very busy at work this 2010 hehehehe
