1-2 years ago I spent a lot of time researching water cooling components. However, I am not updated on the new stuff and what currently is regarded as best performing.
Now I am ordering a WC setup and don’t have that amount of time for research. I have googled a bit, but still need some input.
I numbered my questions to make it easier. Please use the number when replying. Any input is much appreciated. Thanks :)
Radiators:
I want a Quad rad for slow fans, and preferably with low waterflow restriction.
XSPC RX480 vs. ThermoChill 120.4 vs. Feser X-Changer QUAD 480 vs. other quads.
1 - Which is better?
Based on
this German test I found, XSPC RX480 seemed like the best alternative with best performance with slow fans and pretty unrestrictive, but I don’t know how trustworthy that test is.
pick your fav, but don't forget the price/ performance leader Swiftech MCR series. XSPC, HWLabs SR-1 and Thermochill parts perform within margins of error of each other.
2 - Are there any quad 140mm rads on the market?
yes, but not for slow fans
Pumps and pump tops:
I know the MCP355 is regarded as the best performer with an aftermarket top. However, I want to build a silent system.
3 - Would I be better off with a D5 Vario or MCP350, or are the noise differences too small to worry about?
D5 is lower vibration, but once isolated the differences in noise are pretty negligible. MCP350 is also a strong contender, but none of the Laing pumps are contenders with Eheim, Danger Den Db-1 type pumps in terms of vibration. This is only an issue if you do not plan to perform serious decoupling measures with the Laings.
4 - Are there any good D5 aftermarket tops available now? If yes, how will it compare to the best MCP355?
yes, same story as the original pumps- D5 is generally higher flow, lower head, DDC the opposite. Primochill Typhoon3 is worth a serious look once the leaking issues get sorted.
In regards to the MCP355 tops, I have noticed that the EK X-Top Rev 2 has outperformed the XSPC top.
5 - But is it also better the the XSPC Res top?
don't know, but EK also has an integrated top/ res combo that's probably worth a look
6 - Would the pump with a Res Top mounted be more silent then with a normal top?
depends how it's mounted :)
GPU block:
I don’t want a full cover block. I noticed there is a Rev.2 of the Swiftech MCW60.
7 - Has the performance improved, and is it still as unrestrictive as the first edition?
yes and nearly
8 - Are there any other alternatives that outperform the MCW-60?
all within a degree or two, and on a GPU it doesn't much matter. TBH, modern high-end graphics require a full-card solution, whether that be a dedicated fan, heatsinks and a Wb, or a fullcover block. Fullcovers require less airflow, and are, therefore, generally the safer option in a low-airflow environment.
Chipset block:
I’m building a LGA1156 system. The memory controller and PCI-Express are now moved to the CPU, which should mean the chipset would run cooler than before.
9 - Is it even necessary with a chipset block?
no
10 - Is the Swiftech MCW30 still the best in terms of performance and unrestricted flow?
I imagine some of the full-cover blocks are better performing, but neither are necessary
Other:
11 – What are the best performing barbs?
they're too close to really matter, but the Bitspower Fatboy barbs have the largest inner diameter, AFAIK
12 – Which tubing is recommended in terms of quality vs. price?
primochill LRT
13 -
Silver KillCoils vs.
PT_Nuke vs. others. Which works best?
PT Nuke is cheaper and can be used for more than one system, coils are maintenance-free. There are also silver-plated barbs
