Project Fluid Media - Liquid-cooled Gaming HTPC
Edit: Since I noticed from some other threads that people are asking how and where I got the plated MIPS blocks, if anyone is interested in some MIPS blocks (plated or standard) let me know (send me a PM) and I may/should be able to hook you up. I may be able to do plated HeatKiller blocks as well :up:
Edit 2: The Bitspower 45s did not pan out since I did this over the holidays and shipment from Sidewinder got delayed for 3+ weeks at customs (Country of Origin: Taiwan, tsk, tsk, tsk :shakes:...what was Gary thinking) so I decided to go without the 45s. Now I have a spare set of 12 or 14 Black Sparkle 45s lying around. Oh well, another build another time.
Just wanted to make a small build log to showcase what I am doing now. First, the list of key system components :D
ASUS Rampage II Gene mATX LGA1366 DDR3 X58 2PCI-E16 PCI-E4 PCI GBLAN CrossFire SLI Motherboard
Intel Core i7 920 D0 Stepping Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 -SLBEJ-
Corsair XMS3 Dominator TR3X6G1600C8D 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24 Core i7 Memory Kit
Radeon HD 4850 625MHZ 512MB GDDR3 1.9GHZ PCI-E Dual DVI-I in CrossFireX
Nmedia HTPC-5000B Desktop Media Centre Case mATX Black 1X5.25 4X3.5INT Card Reader No PS
Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan
And now a list of key water-cooling components, but before I do that I want to send a special thanks to Doc MIPS for taking care of my requests and parts with first class service. Thanks for getting the plating done for me and handling everything smoothly! :D ;)
MIPS ASUS Gene Series COOLER Set POM Black MCH2436
Watercool HEATKILLER® CPU Rev3.0 1366 LT w/ LGA1366 Backplate
Watercool DDC-Case LT for Laing DDC
Swiftech MCP355 12v DC Pump
Swiftech MCR320-QP Quiet Power 3X120mm - Black
Swiftech MCRES Micro Revision 2 reservoir
Primochill Primoflex Pro LRT White 1/2IN ID 3/4IN OD Tubing (10 Feet)
Premium Bitspower BP-BS45R and BP-BSWP-C01 Black Sparkle 45deg Rotaries and Barbs
Here is the case I will be working with...
http://www.nmediapc.com/HTPC%205000/5000b7.jpg
...and a link to the case with more pics...
http://www.newegg.ca/product/product...82E16811204035
I got mine from NCIX, but Newegg.ca has better pics :)
And finally, the grand finale (for now :p:) here are the initial pics of the water blocks, motherboard, and DRAM...
http://img.techpowerup.org/091222/IMG_5175_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5188_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5190_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5224_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5225_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5226_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5266_1280x853.jpg
http://img.techpowerup.org/091222/IMG_5319_1280x853.jpg
I will be posting more pics as I do more.
Edit 3: See post #9 onwards for more pics of the finished product ;)
