need help watercooling asus matrix gtx 285
Hi all
I got 3 asus matrix gtx 285's for my bday earlier this month and of course my father not knowing anything about gpus would of had to buy a card that is not reference model. Anyway i want to watercool them and i think my only solution is to go for a gpu only block and buy a bunch of heat sinks. My top choice would be the swiftech mc-60 block with some of their heatsinks. My main question is what are all the parts that i must cool on the cards and how? I managed to find a couple of pics on xbit labs of the pcb
main pcb
http://www.xbitlabs.com/misc/picture...front2.JPG&1=1
back or pcb
http://www.xbitlabs.com/misc/picture..._back2.JPG&1=1
i know i can use the little 14x14mm swiftech gold heatsinks on the memory and the long black ones for the mosfets. but how do i cool the chip by the dvi ports? i was thinking a southbridge heatsink? also on the back of the pcb, is it only the 1 line of mosfets on the left that need to be cooled or is there anything else?
the other thought i had was to get the swiftech gtx 285 heatsink and maybe do some minor mods to make it fit?
thoughts and suggestions are welcome.
