[5770] Under dryice, some testing!
Hi guys, been a while since i had something subzero going on, picked up 35Kg of dry ice, just to test the mobo / cpu combo, and put the Xfx 5770 under dry ice! save to say there is room for improvement, but that wasnt really what the run was all about. LN2 results are next up...!
first did some 06:
http://www.hwbot.org/result.do?resultId=920927
Sure i can get a bit higher, but gpu was limited due to the temperature, it'll go around 1200 or more with some liquid nitrogen.
next up was vantage, 03 and aqua were on the list aswell, but somehow i got a bunch of errors every time, think i installed it with a to high freq, o well.:
http://www.hwbot.org/result.do?resultId=920930
Some pictures made during benching:
http://www.thijskramer.nl/tweakersdotnet/SSL24800-1.jpg
http://www.thijskramer.nl/tweakersdotnet/SSL24802-1.jpg
http://www.thijskramer.nl/tweakersdotnet/SSL24805-1.jpg
http://www.thijskramer.nl/tweakersdotnet/SSL24806-1.jpg
Was great fun, thanks snot_aap for the help!
turbo was bugged, think in relation with the coldboot that at -90 or higher life is better, same with the 5770, so next up, LN2!
