Good Afternoon All.
Has anyone had experience of the F3-16000CL9T-6GBTD kit combined with a Gigabyte X58-UD5? I'm having stability issues with the above combination. Any advice would be appreciated.
Regards,
Steve.
Good Afternoon All.
Regards,
Steve.
Try the following settings:
CPU Clock Ratio - 14x for 2.8GHz
QPI Link Speed - AUTO
Base Clock Control - Enabled
BCLK Frequency - 167
Performance Enhance - Standard
Extreme Memory Profile - Disabled
System Memory Multiplier - 12
Uncore & QPI Features
Uncore Frequency - 4008
DRAM Timing Selectable - Manual
CAS Latency Time - 9
tRCD - 9
tRP - 9
tRAS - 24
Enter these for the other three as well.
Channel A Timing Settings
Advanced Timings
Command Rate - 2
Advanced Voltage Control
Load-Line Calibration - Disabled
CPU Vcore - 1.30V
QPI/VTT Voltage - 1.30V
CPU PLL - 1.900V
PCIE - AUTO
QPI PLL - 1.300V
IOH Core - 1.400V
ICH I/O - 1.600V
ICH Core - 1.300V
DRAM Voltage - 1.640V
Rest to AUTO
Keep me posted on the results and I will be able to further assist you.
Thank you
GSKILL SUPPORT
Thanks for your reply.
I'll try your suggested settings.
Regards.
