The EK-MCP 4.0 Water Pump is the ideal accessory for even hardest enthusiasts and their water cooling systems, and is compatible with the all standard water cooling system setups. The EK-MCP 4.0 will easily integrate with the latest water blocks and can achieve up to 800L / hour with its compact, powerful and low-noise design.
Extremely reliable and ultra-quiet, the EK-DCP pump will work silently to ensure your cooling system operates at its peak and makes the most for your hardware overclocking potential.
Model: EK-DCP 4.0
Rated voltage: DC12V +/-10%
Starting voltage: DC 8V above
Power Consumption: 18W +/-10%
Load current: 1.8A +/-10%
Q-max: 800 L/hr +/-10%
H-max.: 4.0m +/-10%
Size: 75 x 54 x 66mm
life Expectancy: 50000/hrs at 25°
Noise: 24.5 dB
The EK-MCP 2.2 Water Pump is the ideal accessory for all enthusiast water cooling systems, and is compatible with the all standard water cooling system setups. The EK-MCP 2.2 will easily integrate with the latest water blocks and can achieve up to 400L / hour with its compact, powerful and low-noise design.
Model: EK-DCP 2.2
Power Consumption: 6.5W +/-10%
Load current: 0.62A +/-10%
Q-max: 400 L/hr +/-10%
H-max.: 2.2m +/-10%
Size: 52 x 45 x 50mm
Noise: 17.2 dB
Enclosed:
1 × EK-DCP Pump
1 x Anti-vibration Pad
1 x 3pin to 4pin Cord
2x Brackets
They look good too! Nice and simple.
