So I decided to clean up the wiring in my pc, but didn't want to spend 3 days on sleeving every single wire to perfection. So what I did was I grabbed a few cord organization kits as well as heat-shrink from Home Depot (where I work) and started to organize and sleeve my non-modular power supply as well as a few other cables. (it's a non-modular power supply because it was a return and it was $80.00, but nothing was wrong with it) The wiring kits cost a total of $4.38 and the thick corrugated tubing was $.99 for 10 FEET! - the other tight wrap heat-shrink was $2.38 and came with 2 thicknesses.
The corrugated tubing matches the tubing that is on my Domino ALC :ROTF:
Below is the original wiring job followed by the finalized version.
http://i6.photobucket.com/albums/y23...er27/photo.jpg (so :banana::banana::banana::banana:ing sloppy!)
http://i6.photobucket.com/albums/y23...r27/photo2.jpg
http://i6.photobucket.com/albums/y23...r27/photo3.jpg New wiring job (muuuuuch better :clap: )
It's amazing what you could do with less then $5.00 in your wallet :)
The next step is to get PC Cable Tie Kits that mnpctech sells so then it can be XTREMELY neat to a pin, but I'll save that for next time
