DIY Fan controller
This is my diy four fans controler with on off .If you are looking for modding your PC ans reduce the noise ur fan makes, then this is just for you.
Fully Assambled 4 Fan Controler.
http://i30.tinypic.com/671mhd.jpg
http://i26.tinypic.com/34rva7k.jpg
First fan in action
http://i28.tinypic.com/2w6togo.jpg
Second fan in action
http://i31.tinypic.com/118houg.jpg
Third fan in action
http://i25.tinypic.com/111ou42.jpg
Forth fan in action
http://i31.tinypic.com/5bpo3s.jpg
PCB with component.
http://i30.tinypic.com/54dvle.jpg
Back PCBs .
http://i28.tinypic.com/246qryd.jpg
Custom Fan & LED Controller PCB, Audio Power-amp PCbs, Pre amp PCBs are also made.
For more info PM.
Thanking
Rakesh Sharma
Is this more of a DIY with step-by-step instructions, or will you be mass producing these? :D
How much watt can these handle?
I got some 5W San Aces that I want to make silent.
DIY FAN Controller Fully completed.
I have completed the front panel for
my DIF fan controler.
http://i28.tinypic.com/4ij8xv.jpg
http://i27.tinypic.com/2hi9zpv.jpg
http://i30.tinypic.com/2lcxjyx.jpg
Now fits on empty 5.25 bay.
Voltage control IC in each channal is a ST product and can handle 8amp of current with voltage output from 1.2 to 26v
Practically you can run 6 X 140mm fans on one channal (but in that case one have to use bigger heatsink) so lot of power.
Ok now i am onto RAM cooler.
Please tell me which orientation of fans is good
Type -A
http://i25.tinypic.com/2j2b4b4.jpg
OR
Type -B
http://i26.tinypic.com/262w6xc.jpg
This is what I am going to do.
http://i32.tinypic.com/1zz2qf8.jpg
Install side slot stopper with spring action and 10mm foam to hold it tight with RAM slot.
Form will give it a good grip and also help in reducing vibrations produced by fans.
Will finish the product by 2moro.
