i7 920 and Memory - How much trouble am I in??
So, I just swapped out my old Motherboard and CPU for a i7 920 and the ASUS P6T6 Motherboard. I kept my OCZ DDR3 that I used to use - but when I was reading though the Motherboard manual just now - I saw a big warning that I should be using low voltage memory.
Right now I have RAM rated to run at 2.1V - which is over the 1.9V it says I should be using, and says also that I might permanentally damange my CPU.
So, I rushed to Newegg and order some new RAM:
http://www.newegg.com/Product/Produc...82E16820227365
But between now and when I get it - am I going to damage my Motherboard / CPU???
Right now I have the RAM voltage to Auto - and I can't find any program that will tell me what Auto is setting it to -not CPUz, not SpeedFan, not HardwareMonitor.
Should I not use my computer until the new memory arrives? Or will I be safe as long as I don't overclock a thing?
