AutoC plan
I have been toying with this for some time now.
Have the following here right now.
Compressor - Toshiba PG180X1T-4CZ (out of a 12000 BTU AC unit from Homebase currently gased with R407c)
Condenser - Luve STVF47
Lineset - Poitres job
Gases - C02, R600a, R404a, R1150, R134a, RS24
Is there chance i can use ether 2 of the gases i have to make a nice clean and simple AutoC with this 12000 BTU comp?
Well Auto Cascades are very difficult to tune, I hope your ready for it, personally I think your best bet for an auto cascade is R290 and C02 or like r404a and r23 the first being the cheapest route and out of the gases you listed I would think you may be able to do R600a, r404a and r1150 this mix may work but I hope someone could confirm this.
Even if that mix works using ethelyne in a single stage auto C I heard is troublesome and even the more experienced guys have a hard time tuning them but it would be fun.
R600A and R1150 will work, going to need a long auxillary condenser on that one. And will work better if you could source some R14 for an additional stage (including another phase separator and heat exchanger)
