CUDA Question -- Deciding which Card to buy!
Ave,
Anyone here with CUDA Knowledge/Experience .. I have a question for you.
I'm upgrading my video card from an ATI Radeon X1950Pro to an nVidia GTX card. The primary, or I should say, the *ONLY* reason for the upgrade is CUDA. Please note that I do not play games or use this system for anything except Video Encoding. And that's where CUDA is the most important reason.
I'm using an application called TMPGEnc Xpress which has extensive CUDA support in it's most recent build, and I want to capitalize it.
Here's my Question:
Is the CUDA features/power different as you go higher up the GTX Models - Or is it the same? In other words, does the Core Clock, Core Processors, Memory etc. make a difference to the CUDA power at all?
More simplified ... will I get more CUDA Power/Speed using a GTX 275 then I would using a GTX 260?
Thanks.
