[DeDaL] MiniGUN 1.3 LN2 POT UPDATE!
Pics
http://s56.radikal.ru/i151/0906/9e/807773815cbbt.jpg
http://i062.radikal.ru/0906/20/7d1d60f7a696t.jpg
http://s61.radikal.ru/i172/0906/89/19baf45c6855t.jpg
http://s54.radikal.ru/i146/0906/c6/f9ac2119d5eb.jpg
The main idea of the pot is “pot inside the pot”. When the system is in idle mode we fill up with LN2 only the central section in order to maintain temperature level of the pot. When resource-intensive benchmark is started we fill up big outside chamber. This allows to control the temperature more comfortable. Also you can remove the central tube by turning it off when a strict control of the temperature isn’t necessary, for example when you are benchmarking AMD Phenom II.
Later we’ll perform test results. :yepp:
some links
http://occlub.ru/forum/showthread.php?t=24
http://occlub.ru/forum/showthread.php?t=93
