DFI RMA Service ? 88 error
Hi ! My mb (LANPARTY UT X58-T3eH8) seems to be dead . I simply get 88 code problem on my motherboard when I power it on . It appears immediate : Power On -> Prompt Stopped at 88 (as described in user's manual) . No idea what had happend , no signs before noticed , computer was working fine . WHAT I have noticed - fan on my graphic card (gtx280) is not spinning - looks like no power supplied to it. (other fans in case are spinning fine) But I tried to power on when there was not graphic card installed and the same error code appeared (88) - I have no idea if there should be the same error code when graphic card is not detected/installed in PCI ? Also have tried to remove RAM memory and the same error code... Moreover Clear CMOS , battery removed for more than 3 hours , Secondary RTC Reset didn't help either.
Today I had chance to check my PSU and GPU on other computer and they are working fine , so it looks that it's not PSU or graphiccard problem. Also I borrowed my friend's GPU (8800gt) and it was also not working with my mobo (immediate 88 error and black screen all the time)...
I am staying in Poland where there is no DFI Service available. On Dfi.com there is possible to ''service request'' but only in (Belgium , France, Germany, Luxembourg, UK, Netherlands). I have already written email to Technical Support Team for European Countries ,
Link: http://www.dfi.com/portal/CM/cmsupport/xxcmSupportTeam
I described problem, gave all details about motherboard (rev. s/n etc) . I heard that they proably will give my RMA number and address to send my motherboard to their service. Is it true ? Should I be given RMA number & address ?? ;/ (of course mb is under guarantee & and I have invoice)
Any advice ?
Thanks for your help.
