As the title states, I am getting one tomorrow, and wondering if anyone is using one right now. I'd like to see some setups to get pump placement options. 2 x MCR320's are going in there in 2 loops.
I'm using it, though haven't been able to install my WC gear into it yet. (My 4890 was DOA, so I decided to postpone full set-up until I get that back).
Though, I have left the side-panels off of it, and it is giving me ideas... many ideas...
Though trust me, this case is a DREAM... it is top notch. Glad that I picked it over, say, a TJ-07.
its good for the price (I have one for my computer at work) it has great features and usability but its quality is eh for me, but that mostly just finishing quality like the brushing of the aluminum isnt perfectly straight on the panels and the hard drive racks are poorly designed.
check out Malik's worklog ... i remember he used the same casing
Yea, I got it at a great price, and a windowed side panel as well. I'm thinking tripple rad up top, and then put my second tripple rad on the backside of the harddrive area, barbs at top facing into the 5.25" bays, which is where I will keep my pumps, as I am not running even a DVD Drive. Res placement may be a little tricky...
I have a EK res mini (100ml I think?) and a mcres micro from swiftech. I'm sure I will figure something out.... Thanks guys!
I have the same case now and want to make two loops too. Want to ask - is it possible to mount 4*120 radiator on the top of the case ?
Got it all together! Managed to keep all the stock 240mm fans, and stuck some 1000rpm Gelid silent 12's on just for good measure :)
http://images.ncix.com/forumimages/F...8BC3093F24.JPG
http://images.ncix.com/forumimages/1...D72CCE84A5.JPG
DAMN, that looks great!
What tubing?
EDIT : I see TFC marking, acid green or normal green?
Nice job man !
I have just started to build my WC in ATCS840. And my ideas are the same as your case.
I have only two questions. What is your upper triple radiator and are there any other 12cm. fans on push, or you you only the stock 23 cm. fans ?
For MomijiTMO, its Feser Acid Green, yes. I likes.
Kayso, I have the stock 230mm fans in place at the top as Pull. I used a MCR320 RAD. I then used the included 120mm adapters to attach the Rad to those fans. Then, I used 120mm Gelid Silent 12 fans, in Push. All in all, very silent. The loudest thing in the case is my 1000W Ultra X3 PSU.
I started my build with ATCS 840. I think the case is very nice and very easy for watercooling :)
Here is where I'm for now. Both radiators are Thermochill with the new 15 mm. spacing :) Unfortunately TC are thicker then Switech so I wasn't able to keep my big fans. But 6 Yateloons on push->pull fits just perfect :)
http://media.snimka.bg/3430/013116214-big.jpg
http://media.snimka.bg/3430/013116220-big.jpg
you should have the top fans blowing into the case, better temps :up:
Rear fan + PSU + lots of vents in this case ;) air will go out on its own and you wont get dust coming in your case if you filter the fans
I just got one of these and I plan on doing something like the previous posts here. I'm just curious why nobody has tried using the standard 200mm fans as a push for the top radiator and having 3 120s pulling through the top rad. I saw Coolermeister do this in his build and it looks like a great way to keep noise down while getting some pretty good airflow coming in.
Thats exactly what I did, but I made them Pull. I am now thinking of changing them to Push based on what snipe is saying...
You can kind of see it here : http://www.hardwarecanucks.com/image...c76bc17d34.jpg
I dunno, maybe in the ATCS it would make more of a difference. In the TJ09 I found no difference whatsoever in temperatures whether the top rad fans were intakes or exhaust. The airflow in the TJ09 is so good that perhaps the air wasn't in the case long enough to heat up enough to make a difference. I suggest you try it both ways and see which one works for you. Hard to make a recommendation because there's so many variables that I don't think it's possible to conclusively, globally say which is better for every situation.
Because if you use double thickness radiator like Thermochill or Feser with standard 25 mm fans ., it won't fit. It will be too thick. Keeping 23 cm. fans is possible only with Swiftech radiators or similar.
Other option is to buy slim fans with 20 mm. and with them to keep original CM 23cm. fans :)
Sorry but my english is not very good :)
