Lost time is never found again.
anyone would kindly post a link to download the original spd of corsair xms2 1gb stick?
got a dead pair over here because of messing around with spdtool.
thx.
thx. i'll try arriving at home.
is either of these downloads a full version or are they just shareware?
I get errors attempting to run any of these, on every system I have. I'm missing drivers and control files?
Awesome VVJ :toast:
If my settings aren't sticking in thaiphoon is that because Im using the trail version or because my SPD is locked? I get no message confirming either.
wow....good work....your an asset to the community.... thanks for the app....
keep getting app not found after dll.....
Great and very usefull !
Whats the rationale behind that? :confused: These days most people that are interested in mods and OC sits on a x64 OS, which renders this software useless for them. I would even venture to say that companies and corporations more than not sits on a x32 box. It seems a bit backwards to me.:shrug:
7.1.0.0 build 0404 Final
http://www.softnology.biz/files/thphn71.zip
Cool thanks stasio
trying the demo in windows 7 64bit, it doesnt read the ram.
File not found error.
7.3.2.0 build 0822 Final
http://www.softnology.biz/files/thphn73.zip
http://www.softnology.biz/files.html
This is back to demo, whereas below it was said you made it avail to everyone (non corp. would assume).
You want to charge for something, yet appear you can't be bothered with WHQL validation and having your driver properly signed. You are not ready to charge for it, if you can't get it signed.
You don't provide a means to CLEAN UP your install of the driver. Your services key is nxIO32, yet its a 64 bit driver, and I would like to know why you put it in they SYSWOW64\drivers key? You want 64bit drivers to go in the correct location *AFTER BEING signed*, your service key should be either nxIO, nxIO32(for 32 bit), nxIO64 (for 64bit). More importantly, you need to provide instructions on having your exe, clean up after itself and uninstall the driver.
I'm all for you charging for your time/labor into this software if you chose to go that route. Just make it a real program with the features AND SECURITY (signing) processes followed.
Take care,
R
See if this helps you with your 32bit exe/installer. Disable(WOW64FSREDIRECTION). Use Enable(WOW64FSREDIRECTION) to turn it back on.
Who is this "you"? :confused:
You mean VVJ ?
13.0.0.0 build 0405 Final
http://www.softnology.biz/files/thphn130.zip
15.0.0.4 build 0404 Final
http://www.softnology.biz/files/thphn150.zip
16.0.0.4 build 0612
http://www.softnology.biz/files/thphn160.zip
