Best X58 Motherboard for 2-Way SLI
Hello,
Long time reader, first time poster lol.
I am in a bit of a pickle. I recently built an i7 system with the following:
CPU:Core i7 920 @ Stock with a Vigor Monsoon III LT
MB:Asus P6T
RAM: 6GB Triple Channel OCZ Platinum 1600MHz
GPU: Dual GTX 275s in SLI
HD: Dual VelociRaptors RAID 0
PSU: Corsair HX1000
Case: Thermaltake Armor
Since the build, I have found a few issues. The 275s are getting very hot. The top card often reaches 93C with a full load and 100% fan. Another problem is that the P6T does not have a heat pipe between the Southbridge and the IOH. Since the 275s are sandwiched together right over the Southbridge, it gets no airflow and often overheats. The first sign of it overheating is my PCI X-Fi card will start to cut out. My room temperatures are usually around 25C.
To solve this problem, I had to move my second GPU down to the third PCI-E slot. This slot, however, only runs at 4x. So, I then decided that I need to get a new motherboard, case, or both.
I've ordered a new case, hoping for better air flow. I ordered the HAF 932. It should come tomorrow. When it comes, I see what the GPU temps are with the HAF. I don't think it's going to fix my Southbridge problem, but hopefully the GTXs won't get so hot.
If I find that the GTXs are no longer getting that hot with the new case, my options for a new motherboard will greatly increase. But right now, I'm looking at the following motherboards because they will allow 2-Way X16 SLI without the GPUs being right on top of each other. I have excluded the Asus P6T Revolution and the EVGA Classified. I have a sour taste in my mouth because of this P6T. Up until this point, 95% of my MBs have been Asus. And the EVGA Classified with 3-Way X16 SLI is $450.
The motherboards I'm considering are:
EVGA X58 SLI
DFI LP UT X58-T3eH8
Foxconn BloodRage
Asus P6T Deluxe V2
If I find that my new case fixes the problem of the GPUs, I think my first choice of MB would be the Gigabyte X58 Extreme as it seems to be a huge hit here.
If anyone has any success/horror stories about the above mentioned boards, or you know of a better board given my situation, please share. I would also like to hear if anyone is getting similar temperatures with the 275s in a 2-Way Heat Sandwich configuration. :rofl:
