4870x2 CF - Voltage Factory + Win7 64bit RC ?
Anyone know if Voltage Factory app works with Win 7 64bit RC and 9.4 (8.612WHQL) Drivers with 2x HD4870x2 Crossfire ?
I have 2x HD4870x2, one HIS brand does 860/950 stock hsf/bios and one Gigabyte does 837-842/995 stock hsf/bios. But together on Win 7 64bit RC in CF, can't seem to get past 847mhz on GPU if both cards clocked the same even if i raise voltage from 1.26v all the way to 1.34v on Gigabyte card.
http://fileshosts.com/intel/DFI/DFI_...ory_setup2.png
http://fileshosts.com/intel/DFI/DFI_..._rivatuner.png
without touching volts 832/915 is easy start although GPUZ doesn't report correct clocks heh
http://fileshosts.com/intel/DFI/DFI_..._915_28902.png
