AMD to Intel: "Real men use real cores"
According to an interview posted on April 6th, AMD's attitude toward Hyperthreading is that real cores are better.
Real men use real cores. We’ve got real cores across our products. Hyperthreading is basically designed to act like a core except that it only gives 10 to 15 percent performance bump for real applications workload. That’s because hyperthreading requires the core logic to maintain 2 pipelines: its normal pipeline and its hyperthreaded pipeline. A management overhead that doesn’t give you a clear throughput.
I have to agree. My assessment is:
Real cores = manmeat
Virtual cores = strap-on.
Comments? :D
I m sure about the whole real men thing....
but he does have a good point here.
Now, Intel will rave about the performance of QPI but it’s only if you buy their top end parts. If you buy their mid-range parts, the QPI speed drops down, and if you buy their lower end parts the QPI speeds drop down even more.
Meaning that if you have an application that rely on high I/O and high memory throughput but doesn’t need a lot of compute power, like a Web server, a file server or network infrastructure - which are the real backbone of today’s data centers - you would have to buy the fastest Nehalem processor to get the fastest QPI! Instead, we offer the same HyperTransport speed on all of our Opteron chips.
