Lian Li A71B, Dual Loop (i7, 4870X2, Bloodrage)
First of all i have to say, that this build isnīt about look at all. I got a second pump for cheap and i decided to split my loop to a seperate GPU/NB and CPU Loop. I also want to get everything inside the case this time. The Case will be completly closed with no window and i will put some noise-absorbent mat inside.
Hardware used (as in my sig):
Core i7 920
Foxconn Bloodrage
4870X2
Corsair HX1000W
6GB Corsair Dominator PC1600CL8
Loop1:
Thermochill PA120.3
D-Tek Fuzion rev1
Laing Ultra /w Alphacool Top and RES (i hope i can bleed this out, otherwise iīll get me an XSPC Top)
Loop2:
Thermochill PA120.2
XSPC 4870X2 Acetal
Bloodrage NB Block
Laing DDC-1T (non Pro/Ultra) /w Zern Top
EK Multioption RES 150ml
Here is a former Pic of my build:
http://img249.imageshack.us/img249/9332/img0088.jpg
http://img249.imageshack.us/img249/4052/img0155.jpg :D
What Iīve done so far:
Mostly cleaned up some parts and the case. Had a hard time mounting the PA120.2 in the front, but then a i had an idea about using cable ties and it works perfecty ;) Also mounted the Res with some cable ties.
http://img512.imageshack.us/img512/7824/img0158t.jpg
http://img249.imageshack.us/img249/6568/img0159.jpg
http://img249.imageshack.us/img249/525/img0160.jpg
Next things to do: Cleaning my PA120.3, putting the noise-absorbent mat in my case, put together the case again.
I hope iīll be able to finish this within ~1 Week, i got some stuff to learn and mabye i need to order some more parts (XSPC Top, Fittings) but i donīt think so.
And i was thinking about adding a T-Line for drain on Loop 1, maybe iīll ask you guys later where to put it, but first of all i need to do some other things ;)
Enjoy
