Hey Guys,
I´ve just ordered Koolance X58 + EK Mosfet blocks, and i´m planning that they should have they own loop ...
But which radiator should i use?
/ C4PPY
Hey Guys,
/ C4PPY
If all you;re cooling is the NB, SB and mosfets, I would think a fatter single 120mm would be good.
But a dual 120 would work for sure.
I am using a Black ice 2 extreme 120.2 for my processor and NB right now and it's just fine.
Monsta :D
Doing build with the same mobo today: http://www.xtremesystems.org/forums/...d.php?t=222100
Using TC PA 120.3 for Tri-SLI'd 280s, TC PA 120.2 for Mofsets/NB/SB/PSU, and PA 120.2 for CPU
Thanks for the replys, i´ve bought 1 x BlackIce 360 Xtreme ( got one already ) + 240 Xtreme .
So my water setup gonna look like this:
Dual laing D5 -> BlackIce 360 -> EK Supreme -> BlackIce 360 -> X58 QPI + NB -> Mosfet ...
Maybe i´ll buy two more GTX260 and watercool all of them :P
Is that 12 gig of RAM in there?
or are they 1 gig sticks?
I have the 6 gig set and it was hard dropping the 320 bucks for some bling.
Worth it IMO though.
C4PPY,
You should be fine with going from the cpu into the board block and then out to the other rad. I also think with the 2 rads you got there would be no problemo adding gpu blocks too.
The black ice rads are pretty good. My 120.2 is more than good for my processor and my NB by itself.
