i have the sapphire 4670 with GDDR4 memory, and i want to vmod it to squeeze a little bit more out of it!
anyone know how to mod it or do you need me to take pics?
mvh/Tommie
mvh/Tommie
i figured out by myself how to mod this little mf, here is the modded card.
http://geting.se/image.php/159656-Vmod.jpg
how far can i take the vgpu ?? im currently at 955mhz/1163mhz @ 1.525V/2.17V
can i go any further than this? temp is 61C with stock cooler at 100%.
IS THIS FORUM DEAD ????? It took me AGES to be activated so i could post, and now no one is fawkin answering! i have written in 4 threads different questions, and haven't got any replies..
does anybody know how much voltage the RV730 can take?
Hi guys!
Who could tell me what is this?
http://img27.imageshack.us/img27/989...eroswitchi.jpg
This is on the rear of my Sapphire 4670 1Gb...
http://img8.imageshack.us/img8/9370/switchn.jpg
Thanks!
what is the default voltage
you should be good. i would avoid running fur mark and would cool any vrm. what kind of cooling are you using
the standard cooling at 95% fan speed. i dont understand the vrm part ?? is it the transistors feeding the GPU ? there is no cooling at all on them now...
what do you think about 1.635-1.645 ?? i want 1ghz so bad :D it went through 3Dmark 06 with that setup and didnt go higher then 62C at any time..
the plan is to put a modded cpu cooler to the gpu.. hopefully its larger fins an the bigger area of the fins will give me better cooling.
This mod is identical to the 4850's in a way :)
Well, good to know!
I have one little HD4670 in my HTPC just waiting for some soldering love :p:
BTW 1.72V is impressive for 55nm GPU. Long time ago I've modded X1300Pro and once reached 1.7V my card died! (still at that time I had GPU clock record for it with around 720MHz and 3DMark05 score of ~3600 points :cool:). To be fair it wasn't GPU itself which died, but something on the PCB.
i think the chip itself could handle more than that, but the VR part of the card got awful hot! even the backside of the pcb was to hot to touch ^^
If you want to remain in "safe" levels with your vmod, don't exceed more than +10% voltage for the GPU and memory.
good point.. its not in any way a recomendation from me to push 1.72V through your gpus. its almost 30% more voltage than stock..
