Gigabyte UD5P quick review and time Trial
First I must express great thanks to MsiMax lending and sending his board to me for testing.
BIOS BUGS
Gigabyte reps if you read this these need attention asap
1. Ram clocking is hindered in f4d ( these appear to be fixed in a beta )
2. HT defaults at 2600 ( appears to be fixed in beta )
3. FSB clocking is hindered with X fire, max I could get 214 fsb
4. FSB clocking is hindered with single card, max I could get was 245 fsb ( I threw plenty of voltage at it )
5. DQS training should imho be default to disable and upon a failed OC attempt
6. Bank Swizzle should imho be enabled by default
7. TRFC is stuck on 1T option regardless of setting in bios CPU-z screenshots confirm this
Lets start with a picture show, and personal thoughts and opinions.
Let me state that seeing a board and having it on a bench to experiment with various configurations are 2 totally seperate things.
I try to be unbiased as possible and here's an example......As you can see from this pic tall ram sticks are an issue in the inner banks with a popular cooler like the xigametek 1284 EE. ( goldbrick it appears your ram still has a use after I killed it :up: )
http://members.cox.net/bostonreefer3/UD5P1.jpg
Ram with the more common heatspreaders are not an issue although still require the xigamatek to be unlatched for inner dimm installation...
http://members.cox.net/bostonreefer3/UD5P2.jpg
I took this one step further and tested the True 120 clearance.....
http://members.cox.net/bostonreefer3/UD5P11.jpg
As you can see with a True the inner dimm installation can be done rather easily.......the blame is now rather subjective.....
http://members.cox.net/bostonreefer3/UD5P12.jpg
PWM for memory
http://members.cox.net/bostonreefer3/UD5P3.jpg
PWM for cpu
http://members.cox.net/bostonreefer3/UD5P4.jpg
Loading up the available slots with different configurations to show Pros and cons ( the sound card is from another install and is just used as a prop for those that may have a Pci E sound card )
http://members.cox.net/bostonreefer3/UD5P6.jpg
http://members.cox.net/bostonreefer3/UD5P7.jpg
http://members.cox.net/bostonreefer3/UD5P8.jpg
http://members.cox.net/bostonreefer3/UD5P9.jpg
And to wrap it up a full board shot.
http://members.cox.net/bostonreefer3/UD5P10.jpg
I've got a clean install going in now so results later, be patient they will be done when they are done.
