BloodRage: Vcore fluctuating between load and idle
Some of you reported that vcore was fluctuating when the cpu was under partial load or switching from idle to load. This is a result of intel adjusting the VID of the Nehalem family processors on the fly. To prevent this from happening just disable CxE under CPU features in the QuantumBios menu.
Our engineers also recommend to ENABLE vdroop which should actually stabilize vcore.
If you want to use EIST to save power in idle, thats still going to work :)
Hope that helps! :toast:
