Dual Gigabit LAN teaming function
This one, is kinda off topic! and I hope someone can point me in the right direction :P
At home I have X Gigabit + X Gigabit Failover Lan connection.
I know, realtek built'in ethernet device will support in some way the Team Aggregation function, the problem is: I was unable to find the miniport driver, which I assume is called "Realtek Teaming Utility" on the CD provided. In brief, as you could imagine this "driver" will let's them act as one.
Googleing around I found THIS which seems to be v1.0 release driver from realtek.
I've already contacted realtek support, which pointed me to get last official ""Auto installation program (support Vista 64 and Vista) (Submission ID:1317657) 6.216 2009/2/5 5510k GO GO GO"" which doesn't contains this specific utility/driver for getting bonded the two device togheter.
The Driver it's selft are working, but probably it containing some OEM information, which will prevent to load correctly the aggregated port.
So, is there a way for getting Teamed the realtek device builted'in the Blood Rage, on Vista x64?
Thanks again for the help
Best regards
