custom cooling solution for gtx295
currently trying to replace the not so quiet stock fan on a gtx295 by a 120mm fan and a custom duct/shroud.
this involves removing the stock fan to open up the back of the card and let a 120mm fan blow through the back opening of the card directly at the stock cooler to push air from the back of the card through the cooler and out at the front and top exhausts.
my first attempt miserably failed! you won't imagine how efficient this little stock fan is.
from looking at the specs of the stock fan its rated at about 25cfm at 3200rpm!
so my assumption was one of my sflex-e could easy do the job. unfortunately not! even an sflex-f is not able to keep temps in the same range as the stock cooler. as desperate as i was i throw an old delta i had at hand at this, but even this delta was not able to achieve the same result as the stock fan.
it seems that just a fraction of the airflow is actually pushed towards the stock cooler as supposed. putting my hand at the back of the fan, the side where the fan is actually sucking in air, i could feeel a noticable amout of airflow coming back out!
may be the fan simply is not delivering enough static pressure?
redesigning my shroud improved things but still not to the point i expected.
the delta is now able to outperform the stock fan, but as it is as loud as the stock fan its no valid option here.
what fan would you recommend for this situation. guess static pressure is the key here? i'm prepared to get a fan which may be a bit loud, but as long as it is quieter than the 3200rpm stock fan i'm fine.
can there anything be done to get more of the airflow pushed into the cooler and less flow pressed back?
any recommendations? i personally would give a sflex-g a try. any other fan better suited for this appliation?
vapor?
