Intel x48 Chipset and C2Q 45nm Overclocking Thread
The s775 platform is almost set to be phased out soon, but some of us who are usually early adopters have decided to pass up the opportunity to jump on the Ci7 bandwagon; we have a good reason to: armed with proven, albeit a little older technology, we feel our systems still have what it takes for the most intensive applications out there. Be it the P965, P35, x38, x48, or p45, we have come to appreciate the stability the s775 platform offers and are unwilling to part with it yet.
While all the chipsets have their strengths and weakneses, it seems for the x48 chipset in particular, weakness comes in the form of its seeming lack of ability to power a C2Q 45nm to heights the P45 seems to do effortlessly. This is quite understandable since the P45 is a newer chipset and bound to offer significant improvements over earlier chipsets.
While this is generally the accepted conclusion, the results have been mixed somewhat. At least, I have witnessed or been engaged in debates in which I had to question some of these generalizations and conclusions about the x48 chipset. This thread is an attempt to bring together the adopters of this particular chipset to enable us share resources and tips on overclocks and stability.
In my experience with 45nm quad, I find that they can be very volt-sensitive for stable performance but can endure heavy volts as well. This is not to encourage anyone to pump insane volts into their hardware unless they know what they're doing. What I do mean is, some chips do need the volts in order to shine. Careful observation and testing is a must for the best success.
The results below are indicative of my interaction with three 45nm C2Qs and how each responded to my x48 Rampage Formula. I have also received requests for my settings so I'll post my current settings later to day.
I'm on water; all chipsets water cooled. Hardware in my sig. OS is Windows Vista x64 for all tests unless stated otherwise. Thanks.
Richard.
Q9450 @ 8x450FSB, 4GB ram @ DDR2 1080, PL7.
DRAM SKEWS = 300/300 on A/B Channels
DRAM STATIC READ = Disabled
Ai CLOCK TWISTER = AUTO
CPL = Manual
PL = 7
CPUPLL=1.50v
NBV = 1.250v
CPU GTL = x67
NB GTL = x67
FSBT = 1.20v
http://www.hostthenpost.org/uploads/...752e6a4587.jpg
Asus Rampage Formula x48, bios 0308
C2Q Q9550, C1 @ 8.5 x 471 (4Ghz)
4x 2GB G.Skill F2-7200CLD4, 8GB DDR2 942mhz Cas 4, PL7
WC, both chipsets watercooled.
2x 2-disk raid0
Windows Server 2008 SP2 beta (Regular OS)
Only changes from above are;
DRAM STATIC READ = Enabled
Ai CLOCK TWISTER = Enabled
NBV = 1.31v
FSBT = 1.240v
http://www.hostthenpost.org/uploads/...aa681f5c7c.jpg
http://www.hostthenpost.org/uploads/...e4346b758f.jpg
Prime95 small ffts...
Voltages are a little higher here, should take about 1.50v, but my reputation was at stake so I took precautions... ;)
Q9550 @ 4.250Ghz 8.5x500FSB
All settings as above except;
NBV = 1.73v
FSBT = 1.72v
CPU GTL = x62
NB GTL = x67
3hrs done....
http://www.hostthenpost.org/uploads/...dab3c1c70e.jpg
4hrs done and small ffts cycle complete....
http://www.hostthenpost.org/uploads/...be2a93d178.jpg
Prime95 blend....
http://www.hostthenpost.org/uploads/...0b403d8c6b.jpg
Just to give an idea how stable the system is....
http://www.hostthenpost.org/uploads/...2d67857d03.jpg
12hrs+ complete....
http://www.hostthenpost.org/uploads/...93674d44ba.jpg
Q9650 stability test and some fun runs...
http://www.hostthenpost.org/uploads/...4850190c20.jpg
9x506 fsb
Settings same as above except;
PL = 8
CPUPLL = 1.56
NBV = 1.85v
FSBT = 1.72
CPU GTL = x62
NB GTL = x67
SBV = 1.250v
SB 1.5 = 1.60v
http://www.hostthenpost.org/uploads/...212aea9833.jpg
http://www.hostthenpost.org/uploads/...b6551ab970.jpg
http://www.hostthenpost.org/uploads/...0e7a34c7b7.jpg
http://www.hostthenpost.org/uploads/...98be30ce4e.jpg
http://www.hostthenpost.org/uploads/...c3670d1c2d.jpg
http://www.hostthenpost.org/uploads/...93f8b89f0d.jpg
9x511 fsb
All settings same as above except;
CPUPLL = 1.60v
FSBT = 1.80v
http://www.hostthenpost.org/uploads/...ec2b01d42b.jpg
http://www.hostthenpost.org/uploads/...5fe9a80d5a.jpg
http://www.hostthenpost.org/uploads/...8249292d9a.jpg
http://www.hostthenpost.org/uploads/...80bb948c04.jpg
So as you can see, the x48 chipset is quite capable; keep in mind that this chipset is a 90nm node and carries a heavier load of work comparatively, it therefore needs more voltage; the ihs is there for a reason. In spite of this, I was able to run at very low voltages because I kept the chipsets cool with my wc setup. Hopefully, as this thread grows, we shall dig deeper into what works with this chipset. Thanks.
Richard.
