Sorry Folks, I know someone got this to work but I wasn't testing Win7 at the time so I didn't pay much attention. Now I can't seem to find the thread... :(
Any Help?
Any Help?
You need to use Orca MSI editor to change the launch condition to 1=1 then save and run modified MSI. It works fine for 2.1.5 on Win 7 (and Server 08).
Daveburt, copy your installed AOD folder from another PC and move it to your Win7 PC. that will work Im using it now on Win7
I have 2.1.4 installed in XP 32 bit and it works without problems in Win7 64 bit. I use it from XP's folder (I install every program to D: )
I have it but I don't know where you can get it... I tried to look for it once and didn't find it.
I found it and uploaded it to my website. here it is AOD 2.1.4
Any idea when AOD 3.0 is due out with Phenom II support? I know it works now, but it'd be nice to have official P2 support.
Also someone posted a Windows 7 fix for AOD, see http://www.filefactory.com/file/a03e..._Overdrive_rar
I havent tried it but this was over on the official forums @ game.amd.com
Thanks for the help guys.. :D
Copying the whole worked just fine...
Thanks charged3800z24, but the .msi file in that archive still doesn' install.
Anway i can run the program from that archive ;-)
Oh, sorry, That was just the plain 2.1.4...it is the one that doesn't have strange clocks showing etc... I have the Windows 7 mod too, if you need it..
Here!!!
Hey Charged, that was actually the 2.1.5 version as far as I can tell, I'm looking for 2.1.4... ;)
The folder copy thing worked, but I had to take the file off the HTPC which has a dual core and the highest AOD I can get off of it is 2.0.17...
Could you post up the 2.1.4 MSI file for me?
I have it on my XP install but it would be a hassle to get to (swapping cables etc)...
The 2.1.4 folder would probably work as well (but it might be too big), if I could get the MSI file I could mod it using Orca and get it to install. :)
Thanks. Dave
Ya, I got the one that gives the strange clock values, 2.1.5 gives me a core frequency of 4.635ghz :shocked:
I tried using the Msi Installer, and it tells me that I need XP or Vista to install??Quote:
That 2.1.5 I just linked is the windows 7 mod that will actually install in windows 7.
Well, I switched the cables, copied the 2.1.4 folder to a flash drive and copied it to the "Programs/AMD/OverDrive" folder and everything is working fine, with the version I wanted, Finally!! ;)
I also compressed it with WinRar (~6Mb) with the hopes that I could make life easier for other folks to install it on Win7... My only problem now is I don't know of a good "FREE file hosting site"...
I uploaded it to MediaFire, but it spams you to death (almost as bad as ImageShack does with pics :shakes:).....
I don't know of a good "free" FileHost, so if anyone has any recommendations I'm all ears! :up:
Anyway, you may have to jump through a few hoops, but heres the link for the full "AOD 2.1.4 folder":
http://www.mediafire.com/file/zirzmd...14_forWin7.rar
Download it, and put the "OverDrive" folder in "C:Program Files/AMD" and you should be ready to go using Windows 7 and AOD 2.1.4....
Of course you can always copy a shortcut from there and put it where you want... ;)
