Rad testing one 120mm rad is enough for a full system.
hi all after seeing loads of is a 120.3 enought for my system i need more rads ect i decided to do a test how good is can a single 120mm rad be to control temps of a full system if set up right.
o.k build the test rig it heat sources on the loop are
Q6600 @3.6 1.50v
2 x 2900xt's 1.3v core
Cooling
DD tdx block on cpu
ek full cover 2900xt water blocks
eheim 1248 pump
all 1/2 fittings (dd high flow)
tygon tubing only one 90 degree bend
One 120mm rad with Delta 120mm Focussed Flow Fan (EHE) in suck with foam gasket @5v
Os vista ultimate x64 (idle for 20 mins before temps were recorded)
Temps 38/38/32/32 degrees on core (using everest to monitor temps)
Aero enabled idle destop
gpu temps 33/33
just reminding you all the fan is at 5v (pretty silent, going to adjust volts to 7v then 12v if lower fails, system crash)
So guesses on load temps anyone or is the heat dump too great for one 120mm rad (system will crash).
(picts will be uploaded shortly).
