I just ordered a gx2
http://www.newegg.com/Product/Produc...82E16814143128
right now I have 3 Q6600's in vista64.
ds3l with a 8800gt
ds3l with a 8800gt
ip35pro with a 9800gt
my plan is to put the 2 identical 8800gt's in the abit ip35pro mobo. (corsair hx520)
but one of the pcie slots is 4x when used with 2 cards.
from what I've read on fah forums, it should be fine for a 8800gt.
then I'll stick the 9800gt in a ds3l (only one pcie slot).
and the gx2 in the other ds3l (antec 500 earthwatts).
do you see any probs with that setup? I know the power may be close, but hopefully it will work.. the 2 psu's that will be close are the hx520 and the antec EW 500.
and
I haven't done multi gpu before, though I do see a decent guide here
http://www.ocforums.com/showthread.php?t=568770
and fah guide has a small one... but if any of you have any links you'd like to post I'd love to have them.
I plan to use the dual connections on my monitor to get the cards folding.
