Not quite "Xtreme"
This is a point of reference for some of the configurations I've tried on the Bloodrage/i7-920 to gauge my temperatues and what settings would be best for stable, cool, fast overclock.
This is a comparison of temperatures across all cores in relation to the three clock speeds I've tried as well as HT on and off. (Will update as I continue testing)
(Tests were done using Prime95 and OCCT)
All fan speeds, ambient temps where the same across all tests.)
Vcore: 1.136v RAMv: 1.65v
Rounded
1. 20x 190
3.8ghz
1500mhz
2. 19x 211
4ghz
1800mhz
3. 19x 205
3.9ghz
1600mhz
__________________________________________________ _____
1. HT Enabled: Idle-35-33-37-32 20x190
Load-70-69-68-67
HT Disabled: Idle-35-34-38-33
Load-60-69-60-59
2. HT enabled: Idle-36-35-38-35
Load-55-53-56-51 19x211
HT Disabled: Idle-37-34-40-36
Load-63-61-61-58 (Unstable)
3. HT Enabled: Idle-36-36-39-35 19x205
Load-71-77-72-72
HT Disabled: Idle-36-36-39-35
Load-60-60-60-57
I'm using the Cooler Master V8 air cooler. Neither block nor CPU have been lapped by me.
Some random settings.
(19x211 +100vcore unstable.)
(18x225 +100vcore unstable.)
(19x206 +110vcore unstable)
(19x205 +110vcore STABLE! full load 80-82-83-81)
