Hello.
I'm new to WCing and waiting for my last components. I bought a 355 and now considering the position of it in my case. Since, design wise, its better for me to position the pump high up (mounted horizontal) in my case but doing so all of the components will be lower than the pump. I'm doing WC for performance and not looks :rolleyes: :D (OK I don't want it to look like a complete mess :p:). Will this hurt performance? The manual says the recommendation is that you mount your pump at the bottom of your case, and why is that? For now it will be a single loop.
Setup:
CPU: GTZ (QX9770, yeh restriction)
GPU: EK-FC4870x2 (warp issue :yepp:)
NB: NBMAX (yes I know...)
RAD:120.3
Pump: (Swiftech) 355 with XSPC top w reservoir.
Loop: Reserv-pump-blocks-rad-reservoir
Thanks for any info.
