Solution to thermal pad problems
Today I took the heatsink off my 8800GTS to remove the thermal pads and apply a TIM instead.
Problem is that the ram chips would not touch the heatsink without the pads (unlike suggestions in another thread that they would be fine).
Solution?
Not new pads, they are just insulators.
Tape.
Tin tape to be more correct: http://products3.3m.com/catalog/us/e...er/output_html
Thats not the exact stuff I used (I used tin ducting tape for HVAC) but you get the idea ;) Its not as good as if the chips were in direct contact with the heatsink but my overclock has improved suggesting it is doing better than stock. I just cut strips then applied them to the heatsink.. 7 strips on each because its not thick enough with just 1 or 2. Use an x-acto (spelling?) knife to cut the strips to the size of the memory pads after applying them to the heatsink. Its much easier than making 40 individual pieces...
Stock I was able to get 1050mhz on the 1ns Quimoda.. but it would get artifacts sometimes so I just ran 1000mhz usually. Now i'm running 1100mhz without issue.
