Thermalright HR-03GT and HR-11 install 8800GTS (G92)
Hello All,
I wanted to document the install of my new HR-03GT and HR-11 heatsinks from Thermalright.
They are getting installed on a EVGA (G92) 8800GTS in my U2-UFO Case. Overall the install went very well and I am very pleased :D with the results. So on to the pictures.
http://pix.myphotoalbum.com/j/js/jsu...3121.sized.jpg
Above is a look at what I started with. I Went with the ArcticCool PWM fans because I wanted to have the fan speed controlled by RivaTuner.
http://pix.myphotoalbum.com/j/js/jsu...3122.sized.jpg
Here you can see the naked card and the Thermalright Heatsinks for the RAM and other chips.
http://pix.myphotoalbum.com/j/js/jsu...3123.sized.jpg
Here you can see the thermal paste I used to replace the thermal pads that came with the card. The issue I had with this, that even with the washed added to the spring screws, the stock heatsink didn't make contact with all of the memory chips. I had to file down the screw posts to get it to fit flush. As you can see, it did work pretty good and I had pretty good contact all the way around. It was a PITA.
http://pix.myphotoalbum.com/j/js/jsu...3127.sized.jpg
Above you can see the heatsinks for the memory and PWM chips. The thermal tape that came with the sinks was pretty good. I only had to replace the tape on one sink because I dropped it on the table face down. It is a good idea to get some extra thermal tape just in case.
