[XF]ASUS X58 series, true 16+2 phase PWM - P6T Deluxe launch soon !
Due to the 2008 Q2,the brand new next generation processor “Nehalem” (Even the official names call “i7” , but people used to call “X58”)has going to show up, and the spec was no longer like mystery ! code name ”Bloomfield” basically are Quad core processor, 45nm and using new socket level up to LGA 1366, but most important change is Intel Quick Path Interconnect (short name: QPI) to X58 chipset, it’s Triple channel DDR3 and directly control by CPU, not Northbridge anymore, also this is first time we can saw this technology in the Intel platform. So the memory socket has 6 dimms, bandwidth performance has over 1 times than dual channel memory, and PCI-Express slot up to 2.0 version and support multiple graphics configurations from dual to quad graphic cards
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/01.jpg
When you saw this presentation from Intel, you will know the basically spec of X58. this time XFastest.com is brought to you by ASUS P6T-Deluxe motherboard, after the first look report, we are bring to you the P6T’s performance review as soon.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/02.jpg
The board of front side.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/03.jpg
The board of rear side.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/05.jpg
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/18.jpg
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/07.jpg
Northbridge heat-sink is different like usually design, especially you are using the down force radiator, can brings more heat from the heat-sink.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/08.jpg
The ICH10R southbridge heat-sink.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/09.jpg
Also keep the great heat-sink design for mosfet near the CPU side.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/10.jpg
Triple channel DDR3 has total 6 dimm slots, is very shock visual effect.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/11.jpg
Also provide 3 PWM for the triple channel memory.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/12.jpg
CMOS battery postion has move to the memory slot side in P6T-Deluxe, and the special blue jumper is means for increase CPU voltage.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/13.jpg
Back panel for I/O output.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/14.jpg
Normal SATA II port are red color, special port is orange color, this port also can support SAS interface unit.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/15.jpg
Same as P5Q series onboard switch, it’s real convenience for over clocker.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/16.jpg
PCI-Express are using different design for more fasten graphic card.
http://pic.xfastest.com/hyde211/share/P6T_Deluxe/17.jpg
We will update to you every detail of performance testing ASAP, please keep lock on www.xfastest.com , the world fastest 3C review site.
