http://i337.photobucket.com/albums/n...00_7__SP-1.jpg
nice review
how does it do on blend?
Not really a review, but 600MHz stable on air with that board is impressive enough that I'm putting it in Xtreme ocing.
:banana::banana::banana::banana:, now I feel like upgrading my old Biostar P35....
i wouldn't call 1 hr completely stable, but it is very nice for air. What temp. do you have for the nb?
nothing but the free attached heatsink with the board.But I use the AC MX-2 Thermal Compound on the NB chip and the MOS.
Nice but P45 should be able to handle 600 FSB stable without an issue. Not sure if that board is just difficult to achieve that on though. Nice cpu though.
what kind of bios settings did you use?
coolldh, what rev is Your board and what exact markings on clockgen IC? http://ceemic.pri.ee/hardware/tpower/tpower12.JPG
Tnx!
Ver 5.1
good coolldh....600 pretty stable is nice .
I also have rev.5.1 but seems not so highclocker....
which max fsb pi1M ?
my D9 GKX may limit the board's max FSB.About 620Mhz at 2.3V.
CPU Clock Skew 300ps
DDR Voltage +0.200V
Chipset voltage +0.500V
FSB voltage +0.500V
CPU Core1 GTL Ref Voltage 0.63*VTT
CPU Core2 GTL Ref Voltage 0.63*VTT
MCH GTL Ref Voltage Auto
CPU PLL Voltage 1.50V
DDR2 RCOMP Contiguration: Configuration 2
Static tREAD Value(PL) Auto
I have similar settings:http://valid.x86-secret.com/show_oc.php?id=434223
