P5Q-E + E8400 : stuck at 4770 Mhz : need help
Hello,
I would really need help since I don’t manage to maximize the CPU frequency.
My configuration is the following :
ASUS P5Q-E bios 0803, E8400, 4x1 GB DDR2-800 4-4-4-12 Super Talent, Corsair 750 W, phase change cooler, 80 mm fans on memory and northbridge.
I obtain a stable overclock at 9x530 Mhz (30 min Prime 95 CPU blend test OK, Memtest 2.01 OK)
The parameters are the following :
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9
FSB Frequency: 530
FSB Strap to North Bridge: 400
PCI-E Frequency: 100
DRAM Frequency: 1060
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: AUTO
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time: 42
Write Recovery Time: 6
Read to Precharge Time: 3
2nd Information :
READ to WRITE Delay (S/D): 8
Write to Read Delay (S): 3
WRITE to READ Delay (D): 5
READ to READ Delay (S): 4
READ to READ Delay (D): 6
WRITE to WRITE Delay (S): 4
WRITE to WRITE Delay (D): 6
3rd Information :
WRITE to PRE Delay: 14
READ to PRE Delay: 5
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 5
ALL PRE to REF Delay: 5
DRAM Static Read Control: ENABLE
DRAM Read Training: ENABLE
MEM. OC Charger: ENABLE
AI Clock Twister: STRONG
AI Transaction Booster: MANUAL
COMMON PERFORMANCE LEVEL: 10
PULL-INS: ENABLED (ALL OF THEM)
CPU Voltage: 1.4
CPU GTL Voltage Reference (0/2): 0.63
CPU GTL Voltage Reference (1/3): 0.67
CPU PLL Voltage: 1.58
FSB Termination Voltage: 1.26
DRAM Voltage: 2.1
NB Voltage: 1.3
NB GTL Reference: 0.585
SBridge Voltage: 1.20
PCIE SATA Voltage: 1.50
Load Line Calibration: ENABLED
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU CLOCK SKEW : NORMAL
NB CLOCK SKEW : NORMAL
Whatever the FSB from 534 to 580 Mhz, I always obtain a few errors (1 -6) in the Memtest test 7, even if I change the following parameters :
FSB Strap to North Bridge: 333 or 400
DRAM Frequency: always synchronized with FSB
DRAM CLK Skew on Channel A1: every possible option
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5 or 6
DRAM RAS# to CAS# Delay: 5 or 6
DRAM RAS# Precharge: 5 or 6
DRAM RAS# Activate to Precharge: 15 or 18
Row Refresh Cycle Time: 42 or 60
DRAM Static Read Control: ENABLE or DISABLE
DRAM Read Training: ENABLE or DISABLE
AI Clock Twister: STRONG or MODERATE
AI Transaction Booster: MANUAL or AUTO
COMMON PERFORMANCE LEVEL: from 10 to 15
CPU Voltage: 1.4 - 1.45
CPU GTL Voltage Reference (0/2): 0.6 - 0.65
CPU GTL Voltage Reference (1/3): 0.66- 0.68
CPU PLL Voltage: 1.52 -1.62
FSB Termination Voltage: 1.22 – 1.38
DRAM Voltage: 1.9 – 2.14
NB Voltage: 1.2 – 1.5
NB GTL Reference: 0.53 – 0.63
SBridge Voltage: 1.20 – 1.3
PCIE SATA Voltage: 1.50 – 1.6
CPU CLOCK SKEW : every possible option
NB CLOCK SKEW : every possible option
I checked that the RAM is Memtest stable at 1173 Mhz 6-6-6-18. I tested with these validated parameters in order not to be RAM-limited.
I did not check the maximum FSB but I was able to launch Memtest at FSB=580 Mhz.
Since I always have a few errors in Memtest test 7, whatever the bios parameters, I assume that only 1 or 2 parameters are the cause. Or, the bios is faulty and I must wait another one.
Really, I don’t know what to do now. Your help would be much appreciated.
Thanks.
