Hi I'm wondering what is the height of the bottom compartment on the tj07
wondering if a MCP355 with XSPC Laing DDC Top with Reservoir shown Here would fit? :shrug:
Thanks,
Nick
Thanks,
Nick
Yes it fits fine - I currently have mine setup there.
http://www.xtremesystems.org/forums/...postcount=8705
Brilliant Pic thanks! Seems to have plenty of head room to mount the pump on top of some antivibration material aswell
Not a problem - just be careful with the mounting of the pump - make sure it gets plenty of airflow as on things like petras gelstuff they can get quite hot.
Is there going to be a buildlog for your TJ07?
Thanks I'll keep that in mind! (cold water meets hot glass is bad) Not sure how bad things will get with acrylic though.
There hopefully will be a worklog, I'll have to brush up on my camera skills first though.
Though not going to start building things until after i get back from holiday. Heh Havent even left yet and looking forward to coming back :P
I have a few ideas though for case windows....maybe one way window so it looks black like the case on days I feel like a windowless design.
But maybe when a light shines through then it becomes see through? as you can tell I still have some kinks to work out.
