Working: 4870 Overclocking with AMD GPU Clock Tool + Fan Speed Fix
I haven't seen a fix for this out there yet so here's how:
In the .xml file you needed to edit for the fan speed fix, simply remove the following section:
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="50000" />
<Property name="Want_2" value="75000" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="90000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="90000" />
</Feature>
When you set your core and memory in GPU-Z the fan will default back to the defaults. Activate your new profile with the above change and your fan will speed up and leave the overclock untouched. Enjoy!
Now lets see some 4870 overclocking!
