Originally Posted by
Uncle Jimbo
Alex - Your drawing is correct, and with a little care, this is actually easy to do - well easy if you are careful. Using identical supplies for all of the parallel elements is the best way to assure good sharing.
The sense circuits in ATX supplies are tied at the internal circuit board. That's actually a good thing for this kind of design, because the internal wiring provides an effective buffer resistance for current matching.
A typical newer 500W single rail supply puts out 30A at 3.3V, 35A at 5V, and 20A on the 12V line. Given your spec, this is probably what the Keytech 500W has. Older supplies had more on the 12V lines, something like 25A at 3.3V, 30A at 5V and 32A at 12V. Exact numbers don't matter except in calculating the final amperage capacity.
You can also combine all of the supplies in parallel very high current. I would use power relays to do the switching, that way you can do a switch to select the desired output voltages. You can always draw any available output from the 'bottom' supplies (the ones tied to earth ground) no matter what the switch position. . With the right setup, you can select from any combination of those values. So you can get the following voltage/ amp combinations, given 10 supplies with 30A at 3.3V, 35A at 5V, and 20A at 12V:
Always available in any configuration:
3.3A at 150A
5V at 175A
12V at 100A
10 in parallel:
3.3A at 300A
5V at 350A
12V at 200A
Series sets are limited by the lowest amp leg:
3.3 + 3.3 = 6.6V at 150A
5 + 3.3 = 8.3V at 150A
5+5 = 10V at 175A
12+3.3 = 15.3V at 100A
12+5 = 17V at 100A
12 + 12 = 24V at 100A
So that setup can deliver a wide range of voltages at high current. In your layout, supplies 6 -10 are the 'base' supplies - they require no change except combining the wiring, and they are tied to earth ground.
The first step is to tie common wiring together. The existing wiring is adequate if combined - no need to open the supply and do any internal changes. I combined like wires in groups of 4 wires into a spade lug, and then used screw terminals to tie those together, one terminal block for each voltage on each supply. That makes for a nice neat installation and it is easy to change out a supply. I left about 8 inches of wire, just to keep routing options open. There will be more than twice as many black lines as lines for the other voltages. Use them all.
I put a 50A circuit breaker in the ground line for each supply just to avoid any fire hazard.
Next, combine the orange lines from the line to the main motherboard supply, using the same technique.
Finally, do the yellow and red lines. I used all the red and yellow lines coming out of the supply, as they were all common internally on the one I used. Check your supply - don't use any lines which tie to a different point inside than the lines on the MOLEX connectors.
Now you should have a block of voltages for each supply on a common connector, and a ground block with overcurrent protection.
Next, tie the 'banks' together. You don't need any diode isolation or anything like that - it will only create a voltage drop and an additional potential failure point. You should now have two sets of outputs, one for each voltage on each bank.
If you want to use the switching arrangement above, you need to get some big high current relays. You can often get those cheaply. I used 24V relays from an air conditioning control relay, which were rated at 50A per contact. I got them for about $15 each at a local supply house. I just added a standard 24V home heating transformer to run them, they use 24VAC.
That would be an awesome supply and power just about any load you could want. You could even use thermostat type control to pick the output voltage and achieve a wide range of power selections.
