Tried swapping out ocz ddr2 800 was running@1000 for my x3350 for the TWIN2X2048-8500C5D but it wouldn't post.
Should I set my ocz ram to 1111 & then swap it out with the TWIN2X2048-8500C5D to get it to post??
I reset bios jumper also & that didn't work.
I tried using one stick & that didn't work either.
Thank you for any suggestions.
I don't have another compatible system to try the memory on either.
