New System Questions
Ok i just finished putting this togeather and am new at overclocking and such but before i even start going all out i would like to know how these temps are and a couple of questions i know that the bottom is my vid card on speed fan it isnt that i am worried about it is the AUX it seems to be pretty high
http://img329.imageshack.us/img329/6801/tempsgv0.jpg
http://img329.imageshack.us/img329/6...6ab120eb99.jpg
It def looks like your in idle, so your temps are fine but what about at load whe all pistons (so to speak) are pumping?
What fan you got there mate? if it's the intel stock cooler its ok temps!
Thermalright Ultima-90 with a 92mm fan on it
I would check the IHS of the CPU to see if it's flat, seems a tad on the high side for such a cooling setup... is the Ultima 90 also well fixed ? can you move it still a bit ? Which 92mm fan ?
For the Aux readout don't worry, prolly speedfan error
I am using a new Zalmens 92mm ultra quiet led fan system temps after ajusting the heatsink and installing new fan
http://img183.imageshack.us/img183/8...ullloadsi7.png
If I was you I would try a 120mm fan as I thought you could mount that them too on the Ultra 90 models...
