Corsair 4GB DDR2 PC9136 Kit 2D/3D benchmarks @ 600MHz +E7300+9800GX2+Gigabyte X38-DQ6
G'day from Team.AU once again! :D
I received a retail kit of Corsair Dominator 4GB DDR2 PC9136 kit for torture the other day from their latest addition to high capacity DDR2 range.
RAM Specs: http://www.corsair.com/_datasheets/T...6-9136C5DF.pdf
Part# TWIN2X4096-9136C5DF
http://img527.imageshack.us/img527/7...orsairssq8.png
Binned for both Nvidia and Intel chipsets. I prefer using Intel chipsets as they are a lot more efficient on DDR2 platform...........DDR3 platform is different however where 790i rules them all ;)
http://img257.imageshack.us/img257/8...4gbkitbbd9.jpghttp://img169.imageshack.us/img169/9...r4gbkitpd5.jpg
http://img80.imageshack.us/img80/84/1fullsetuprx7.jpghttp://img100.imageshack.us/img100/8786/1ramqd9.jpghttp://img262.imageshack.us/img262/9...bmoduleqk9.jpg
Test Configuration:
Gigabyte X38-DQ6 (F9a bios) STOCK BOARD NO MODS
Intel Core2 Duo E7300 CPU
4GB DDR2 PC9136 Corsair Dominators
Gigabyte 9800GX2 Graphics Card
620W Corsair PSU :up:
TT BigTyphoon Cooling CPU
160GB IDE Hard Drive
Windows XP Pro 32bit SP3
STOCK SPEED 32M SuperPi to warm up a little
http://img146.imageshack.us/img146/9...532msupzi0.png
I've used 2.08vdimm to test max stable frequency
>>>> 596MHz stable with superpi and 3D <<<<
http://img100.imageshack.us/img100/7...532msupka1.png
http://img262.imageshack.us/img262/8...5515am3zt1.png
http://img530.imageshack.us/img530/1...53dmarkgl3.png
GOAL >> SHOOT FOR 600MHz MARK :D
non-Micron ICs have shown a tendency to not scale well with voltage. I've seen this during my testing as well as bumpin the RAM to 2.13v only gave me a semi stable 600MHz even with relaxed tRFC (btw this timing will gain stability with high capacity RAM >> performance toll is insignificant as well ;))
Well time to bump vdimm some more (unfortunately vdimm jumps on this particular Gigabyte board are fairly big +0.05v which sometimes doesn't help with volt sensitive RAM >> new gen motherboards coming out VERY soon have this fixed with incredibly small volt jumps :up:)
RAM bump to 2.23vDIMM
http://img517.imageshack.us/img517/1...532msupmb7.png
http://img262.imageshack.us/img262/4...5515am3ca7.png
http://img155.imageshack.us/img155/4...53dmarkgu7.png
Validation file (509MHz FSB; 611MHz RAM 5-5-5-15):
http://valid.x86-secret.com/show_oc.php?id=357069
http://img146.imageshack.us/img146/9...ory4072jc6.pnghttp://img265.imageshack.us/img265/6...idationml8.png
Did a quick test with this Gigabyte 9800GX2
783-1944-1188 stock card '01 Nature stable :D:D:D
LN2 runs on CPU and air OCs on this GFX coming up soon :up:
http://img504.imageshack.us/img504/7482/1gfxcarddp4.jpg
http://img329.imageshack.us/img329/9...00gx278zu0.png
CPU is not too shabby either for a value chip :D
http://img98.imageshack.us/img98/23/cpu4594hn6.png
i found the trick to high FSB on this CPU and board is to use the new F9a bios (older one was limited to 380MHz FSB :shocked:) and also to use GTL Ref +3% and second one on NORMAL for about 520MHz benchable FSB :)
